Ir para o conteúdo principal
A quarta geração da popular linha de tablets de 7" Galaxy Tab da Samsung.
My Samsung Galaxy Tab 4's Screen Is Not Working..
My Tablet is on and the screen is just black with with blurry lines but I haven't been able to use the tablet for almost a year and it was new.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
It didn't work :( the screen lights up but there's nothing on the screen except the white lines and black everywhere else.
por
same problem comes in my samsung tab..so what you do??
por
If you can open and remove the back cover of the tablet (or ask a tech guy to open it), check the two cable connectors from the screen to the motherboard. One is the LCD and the other is the digitizer. I don't know which is which because I have seen them on tablets that were damages and disassembled. Maybe one of them is not well seated, so carefully press them down, and power the tablet on to check. You can do this without the back cover on and the battery reconnected.
por
Adicionar um comentário
2 respostas
Solução escolhida
You can try a hard reset this will take you back to new all your data and apps will be lost but at least you should have a working tablet
http://www.technipages.com/galaxy-tab-4-...
This is a walk through on haw to do it. Good Luck
Esta resposta foi útil?
Pontuação 2
1 comentário:
Screen is not working touch is not working anymore how can I reset it and if I try to reset it with on off button it sucks it can't reset or switch off my tab is galaxy tab a9 plus
por
If it’s almost a year, and it was new, it will be covered under a warrenty
Pontuação 0
Adicionar a sua resposta
Jessica Goode será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Ao todo: 5,576
