Ir para o conteúdo principal
Repair and disassembly guides for Brother printers.
352 Perguntas Visualizar todos
Brother Printer HL-2270DW Paper jam at front. HL-2140
The paper is jammed at the front. It is half torn off - cleanly. I cannot remove the cartridge.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
The problem maybe the drums that drag the paper, the are worn up to the point they have no rugosity. Try to scratch them with your nails or with the tip of a screwdriver.
Esta resposta foi útil?
Pontuação 1
Normally, people get the paper jam error on their brother machine, when there is a piece of paper obstructing the printer parts. that’s why it can’t print your documents. so check your printer again carefully.
Pontuação 1
Thank you. In this case it was just a matter of removing the toner cartridge and freeing the paper, but I will remember your advice should this happen in the future.
With kind regards,
Kay
Pontuação 0
hello please follow this answer link to resolve your problem https://help.brother-usa.com/app/answers...
Pontuação 0
Adicionar a sua resposta
kay phelan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 3,970
