Ir para o conteúdo principal
The TI-84 Plus Silver Edition is a graphing calculator released in 2004. It includes a USB port, pre-loaded software, APPS, storage, and a removable front and back case.
Why my calculator is not charging?
When I plugged in the charger, it shows greenlight but still low battery even though I charge it overnight
Esta é uma boa pergunta?
Pontuação 8
9 comentários
I read on another site that if you unscrew the battery compartment, unwrinkle the cords, it will charge better. I didn't think that would work, but strangely enough, it is charging and actually working. Hope this helps.
por
how do you open the battery compartment though? mine wont open
por
Sarah Durbin you checked this guide?
por
This worked for one of my students. Thanks for the suggestion!
por
but what if you have the one that is color and doesn't run on batteries
por
Exibir mais 4 comentários
Adicionar um comentário
5 respostas
Pergunta mais útil
Try using the reset button on the back. That fixed it for me!
Esta resposta foi útil?
Pontuação 5
6 comentários:
It worked for me as well!
por
reset button on the back meaning?
por
Using the reset button on the back worked for me too.
por
Where is the reset button?
por
It doesn't work at all...
por
Exibir mais 1 comentário
Pontuação 2
1 comentário:
It worked! thank you :)
por
Reset your calculator: If you turn to the back of your calculator in the mid-left you will see a small button that says reset.
  • Using a pen (pointy) push it and turn on the calculator again.
If this method doesn't work for you then you might have some other problem.
Pontuação 0
If your graphing calculator isn't charging and it doesn't take 4 AAA batteries then it works on a block battery that you have to unscrew the 2 screws and unplug it for 10 seconds, plug it back in and tighten the 2 screws and charge it and it will function normally.
Pontuação 0
Your calculator battery may be reduced in lifespan and it could also be your charging port. You can buy charging ports for TIs and other brand calculator online.
Pontuação 0
Adicionar a sua resposta
faroukiskandar96 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 72
Ao todo: 72,493
