Ir para o conteúdo principal
O Nokia 1110 é um celular GSM de entrada, voltado para pessoas que estão usando um celular pela primeira vez.
earpiece seems dead
the phone has developed a behavior whereby it does not ring at all,
you can hear nothing whether attending to both incoming and outgoing calls, furthermore the normal sounds made when the phone power off and on no longer exists.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
and what if the eapice is good but not working
por Compartilhar
This is a 3year old question. You may not get the help you are looking for. I would post it as a new question. Use this link http://www.ifixit.com/Answers/Ask/Nokia+... to do so and give a lot of details.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
Ok if its just the earpiece that isn't functioning you can find a replacement on eBay.
If the phone's speaker and the earpiece are both non-functional there may be an issue with the logic board.
Please give us more details about you phone, any damages or encounters with water will help us answer you problem as best we can.
-Varsity
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
sammy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 3,757
