Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1502 Perguntas Visualizar todos
iPhone died at 30% battery and wont start again?
For a while I have been using "Mobile Power Station" (an external battery charger) with my iPhone 3GS 32GB.
A couple of days ago I used the phone, connected to the mobile power station, just surfing the web. Then, suddenly, the LEDs on the mobile powerstation started flashing. The iPhone LCD flashed one time and then the phone went dead.
And now, it's still dead. I mean really dead, dead, dead. It won't power on, no charge in neither wall or computer.
I tried soft reset (HOME+Power) and connecting to Itunes in DFU-mode, nothing works! :(
It seems to be a hardware error, but what?
Burned circuits?
When I check the liquid submersion indicator in the dock connector it looks red, just like it suffered a water damage. But I know that my phone never suffered a water damage so I suppose the indicator went red just by humidity.
So my question is, what happend to my phone? what do I need to do to repair it?
Thank you!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
surely, the indicators could have had a humidity "damage" - but they should look a little bit pink and not red - but thats not important.
check the board for fluid residue - it's white/greenish stuff on the small parts on the boardif there is any, clean it with isopropyl alcohol (>90%) and a soft paintbrush
it's possible that the battery is totally discharged (means dead) - faulty batteries can show some crappy data - i had phones that went from 100-0% within 5 seconds - i hate to say it, but i would measure the battery with a multimeter
Esta resposta foi útil?
Pontuação 2
4 comentários:
Thank you! I will try this!
por
Battery change solved the problem! =)
por
great that it worked for you ;-)
por
Adicionar a sua resposta
Bengt Barsebaeck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 8,349
