Ir para o conteúdo principal
Model M8407 / 550 or 667 MHz G4 processor
28 Perguntas Visualizar todos
More RAM chip upgrade
Hi. There are 2 RAM chips/cards in my powerbook. I would like to speed things up. What can I change ? One chip says 256MB. The other is Smart SM564328578NW3R. Thanks.
Update
So if I install 2 new chips do I have to run OS9 and firmware to get things going ?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
You shouldn't have to do anything after adding the new RAM. Either 9 or 10 will see it just fine.
por
Adicionar um comentário
3 respostas
Solução escolhida
You currently have two 256 modules. You do not have to upgrade in pairs so you can remove one and add a 512 MB 3.3V 144 Pin SDRAM SODIMM (PC133) for 768 MB or replace both for 1 GB RAM. Here's the chip you need: http://www.ramdirect.com/vcom/product_in...
Here's a 5400 RPM ATA hard drive that will also give you a boost: [produto vinculado ausente ou desativado: IF107-046]
Esta resposta foi útil?
Pontuação 0
1 comentário:
Pergunta mais útil
iFixit stocks all the RAM upgrades for your machine as well.
[produto vinculado ausente ou desativado: IF111-022]
As long as iFixit is providing all these resources (funded by parts and tool sales), it's nice to support them by linking to iFixit products when available, instead of off-site.
Pontuação 2
1 comentário:
You're correct. My bad. Hopefully they'll soon provide a quality RAM search engine and I'll look to them first. Old habits die slowly and I looked first to where I knew the answer would be and without thinking that iFixit might even carry that RAM I put in a link to someone else. My apologies.
por
The Max RAM for this machine is 1GB, so you can upgrade the RAM, and a faster HDD, thats about all you can do on the hardware side. and im not sure if there are faster than 4200 rpm Pata drives for this machine.
Pontuação 1
1 comentário:
Adicionar a sua resposta
Rick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,661
