Ir para o conteúdo principal
Guias de reparo e suporte para o conjunto do flash externo Canon Speedlite 430EX II.
Why isnt it turning on?
I checked the batts, even tried new ones and still it wont turn on. Is there some explanation for this? I really confusing and i really would like to know the problem before i buy a new one
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Solução escolhida
Check the battery contacts for corrosion - typewriter eraser pencils are ideal for polishing the contacts. The ON/OFF switch can fail - try pushing down as you slide the switch. The switch can be repaired for less than the cost of a new flashgun, as long as you don't go to Canon that is...
Esta resposta foi útil?
Pontuação 12
16 comentários:
Mine did the same thing, and it was battery corrosion - only a tiny bit, barely noticeable, but enough to break the contact. Rubbed it with the eraser end of a pencil, and put the battery back in and it worked. I'll now get some rubbing alcohol and clean it properly.
por Compartilhar
Was about to replace my $300 Speedlite 430EX II, came here, checked the contacts in the battery compartment and boom! Quick scrape and all good.
por Compartilhar
Thank you guys, had the exact same of the battery compartment with the corrosion. Glad I found this.
por Compartilhar
On question guys. my problem seems similar, but the thing is that afer the corrosion because of the old bateries, the switch button to turn on is really hard, its like stuck and I dont want to force it to breack it. Did you have the same issue? Or your issue was that you can switch the button to on but the flash did not turn it on? Thanks
por Compartilhar
Super valued tip!! Using the eraser made it work again!!
por Compartilhar
Exibir mais 11 comentários
Adicionar a sua resposta
itodak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 91
Ao todo: 14,148
