Ir para o conteúdo principal
Released June 2014, identified by model 635.
54 Perguntas Visualizar todos
Why does my phone always turn off randomly
My phone always randomly turns off, I would be texting someone and then it would (sometimes) flash and then turn off and its really annoying me, and sometimes when this happens my phone will be at 50% 60% etc and the phone will say its dead... Plz someone help me as I don't have a clue what's going on?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
MOST probably: It would seem the battery is damaged and needs to be replaced (did you dropped your phone?). Could you ask a friend for a temporary battery swap to check this, or buy a new one.
Optional: Also, consider doing a factory state formatting, this could solve not only this issue, but make your phone faster (it "refreshes" the phone), but take precaution with your data (remove the SD card!) before that and copy all your contacts to your email provider account (meaning, do not have only one copy of the contact, as the formatting will erase your personal data on the phone), write them on an office excel sheet or paper if necessary.
Hope it serves you.
Narmith
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you and I did do a battery swap however all that happened is my phone turned on but the screen went pure blue and stayed pure blue and yes I did recently drop this ??
por
buy a new phone.....
Pontuação 0
Mine switches on and off and then it takes a couple days tell it switches back on
Pontuação 0
1 comentário:
so it did turn on aagain and continue working normally?
por
Adicionar a sua resposta
josh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 3,796
