Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
Front facing camera shutter stuck?
Hi,
I'm having some real issues with my phone at the moment. I've just done a screen replacement and just as i thought all was finally fixed, i went onto the camera. It first appeared to work fine (this being the back facing camera) however when switching to the front facing camera the shutter doesn't open at all. Here's a picture of it :
It's annoying as always when you fix it, another thing happens. I'm not too sure what's happened with the camera as the phone wasn't in working condition when i bought it, so it may have been not working before i got it. It just seems to be the front camera that's gone wrong somewhere along the line.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
UPDATE: Just replaced the front camera and that hasn't worked!! I now have no idea what to do..
por
Adicionar um comentário
2 respostas
Solução escolhida
First make sure nothing is obstructing the camera on the new screen that you installed: remove the camera and look against the light.
If that's not the issue, use a magnifying glass to examine the board mainly next to the front camera connector, but also next to all the other connectors in that area. Let us know if you find something missing/damaged/corroded.
Esta resposta foi útil?
Pontuação 1
Make sure the front camera cable is properly seated on the mother board. It also possible that the cable was damaged during the repair and may need to be replaced.
Pontuação 0
1 comentário:
Thanks for your reply. I've checked and it seems that the camera connections are connected to the phone fine. I tried taking it off and on again ,but no luck. I've just ordered a new front facing camera now so hopefully it'll work! Thank you
por
Adicionar a sua resposta
Stewart será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 206
