Ir para o conteúdo principal
Dell Latitude D630 is a thin and lightweight version of the Latitude line. With a 14.1 LCD screen and a 9 cell battery, this laptop is meant to be more mobile.
Why is new battery not charging
New battery..not dell..but Rayco. Inserted, had power..got home plugged in cord to charge battery. Didn't seem to be charging, and drained to 6% super fast. What is wrong?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I've had the same exact problem with a replacement battery for a D830, the battery I bought was faulty and I ended up spending some extra money to get a legit part.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
You could drain the battery all the way down and then let it fully recharge . Do this a couple of times, so the cells and the chips get formatted properly. If you can't get it to work, you might be dealing with a bad part.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kimberly será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 585
