Ir para o conteúdo principal
Repair information for the Huawei Ascend G7 smartphone. Released in 2014. Model numbers: G7-L01, G7-L03, G7-L11, G7-UL20.
20 Perguntas Visualizar todos
Huawei ascend g7 not charging properly
I plugged in my phone to charge it and walked away, when I came back I noticed it didnt charge at all. I thought it might be the charger so I used another one but still no good. I fiddled with the charger and it worked but I couldnt move the phone. Any ideas?
Esta é uma boa pergunta?
Pontuação 17
1 comentário
Maybe it is a flex cable issue, try a new flex cable to have a try.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
The charging port is damaged.
Try cleaning out the charging port to see if there's any lint stuck not allowing the cable to connect fully.
If that doesn't work you will need a new charging port.
Esta resposta foi útil?
Pontuação 1
2 comentários:
my phone wont charge now
por
change the charging port
por
how to fix the huawei g7-l01 red light charging problem
Update (04/03/2016)
remove the battery from the mobile and replace full charge battery and turn on the mobile and update from the sd card or from huawei sut the problem fix the phone while charging normally
Pontuação 0
2 comentários:
I can't charge my Huawei G7-L11 but when I shut it off and charge it again it work but charging process takes too long 24h charge and it's just 50% sht it's terrible can someone tell what's the problem?
por
and me to ma 4n have the same probleam
por
Adicionar a sua resposta
Mark Gilligan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 13,626
