After repair Phone is rebooting every 30 sec, and no picture
Replaced display assembly and now when plugged in the phone is restarting every 30-50 seconds in addition to the screen not working any suggestions plz!?
Esta é uma boa pergunta?
Randy's answer is probably going to fix it. You might want to go ahead and check all flex cables to make sure they're seated correctly. Also, make sure the power and volume buttons weren't put in a bind when you put the thing together. I have had that happen (I hate being rushed) and had to remove the mid-frame to fix it.
Esta resposta foi útil?
Mine did that after replacing the battery, and found the ribbon connection to the screen was not fully seated
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 157
