Ir para o conteúdo principal
The HTC Desire 510 Android smartphone was announced August 2014.
Why is my phone not charging?
-Updated software on Thursday
-Charged fully on Friday night
-Used all day Saturday
-At bedtime, not unusually dead
-Plugged in to charge and it kept notifying me that the charger was connecting then disconnecting.
-Was using same charging cord as I usually use, tested it on another phone and it was fully functional.
-Phone is now too dead to turn on and shows no signs of charging.
HELP!!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
This could be a battery issue if you have another to try start there if your getting a connect disconnected it sounds like it could be the charging port itself . Try wiggling the cord and see it there's a position that will allow it to charge
http://www.amazon.com/Original-Genuine-C...
the port can be purchased on amazon and is a separate unit so its screw in and hook up your cables and away you go
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ashley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 51
Ao todo: 900
