will the screen from a G71 fit in a G72
I need to know if the two screens will interchange
Esta é uma boa pergunta?
You must match the resolution, backlight, and screen size to your current screen. You cannot deviate from your current screen specifications. A screen with different specifications will not work with your system.
In this case--you should be able to, yes, as both laptops use identical screens with the same 40-pin connector. Worst case scenario, you're looking at about a $70-$75 part.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 168
