How can I fix the charger piece on my Kurio
I need to know how to fix the charger piece on my Kurio
Esta é uma boa pergunta?
I have successfully replaced the micro USB connector on a Kurio tablet and documented the process here: Repairing Kurio Tablet Micro USB Connector (charging port). However, as Miles noted, this is a very difficult repair, so I would not recommend trying it unless you are comfortable with soldering at fine pitches. Simply replacing the mainboard with a new one from eBay would be significantly easier.
Esta resposta foi útil?
The charger piece is chipped can u please help me fix it on my kurio 7 s tablet
Hi from the pictures i can find of the motherboard it looks like the charging jack is soldering to the motherboard and to replace it would require a new one to be soldering on. I was unable to find a replacement jack so one would need to be pulled off another board. This will require someone fairly skilled in soldering to fix it. And unless the tablet has super important data on it i would either recommend buying a new tablet or one that uses a much more standard jack for charging such as micro usb on a nexus 7 or 8.
Kurio charging port Bent
Good and helpful
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 3,290
