Qi modification sticker NFC
Will it be possible to install this insted of the NFC only sticker on D6603?
Esta é uma boa pergunta?
I do not believe there is a QI receiver. I think these are falsely advertised where the seller is not aware of what the product is.
Esta resposta foi útil?
What about the wireless charging cable on IFixit store? [produto vinculado ausente ou desativado: IF312-057] isn't it a QI receiver? or is that for the magnetic charger?
Correct. The one on iFixit is for the magnetic charger. The Experia Z3 has a separate magnetic charging accessory.
Thanks for clarifying. I got confused, since it says "wireless charging cable".. alas, "wireless cable", now that I think about it, sounds really dumb.
The easiest way to convert the Xperia Z3 to Qi Wireless charging is to use a Qi case, if you don't mind the bulk.
https://www.amazon.com/cellphone-Cases-A...
Apparently all the table chargers at Starbucks are being to converted to Qi.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 613
