2010 MacBook Pro 13" EEE Code / Logic Board
I need a logic board, but my Macbook Pro does not power on. I was unsure if I had a 2.4 Ghz or 2.66 Ghz and after looking at images and comparing, I finally read about an EEE Code.
Some sites state the EEE code is not the same as the Serial Number, but differs for the logic board itself. After looking at the 2.4 Ghz and 2.66 Ghz, where the letters of DD7F or DD7G are listed, these didn't not appear on my sticker.
After reviewing my sticker, of all the number combinations, I noticed the DD7H in the MLB No. Assuming this is correct, it pertains to the 2.4 Ghz which is what I ordered (fingers crossed).
I've attached a picture of my logic board; can someone confirm if this is the correct logic board for my Macbook Pro?
Thanks, your help is highly appreciated.
Esta é uma boa pergunta?
6 comentários
Your board identifier is 820-2565-A, and made in 2009
por Dan
Can you give us the last four digits of your systems serial number so we can correctly identify your system.
por Dan
Dan, the last four digits are TATM of the serial number on the bottom case. When I use the number on the Apple site it shows up as a Mid 2010.
This the the information shown on the Apple Tech page when I type in my serial number https://support.apple.com/kb/SP583?viewl...
Thoughts?
por zerimar3
Here's what EveryMac shows: MacBook Pro 13" 2.4 GHz, Core 2 Duo (Mid-2010)
por Dan
These are the two systems that are part of the series your MacBook Pros serial number tells us: MacBookPro7,1 from EveryMac as an additional reference.
por Dan
Exibir mais 1 comentário
