All the propeller lights are red.
After a crash! All four motor propeller lights are red. No wifi output is noted.
Check the motherboard connections and they are all connected.
Esta é uma boa pergunta?
Check the rotors for damage, if you see any chipped teeth on the gears then that is the source of your problem. Is there any visible damage to the ultrasonic sensors on the bottom? Let me know if any of these are damaged and we can proceed from there.
Esta resposta foi útil?
All rotors look intact without damage. The gears look fine. I do not see any damage to the sensors.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 459
