Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
LCD replacement
Hello! Is it possible to replace LCD in my damaged iPhone 1st gen without touchscreen and glass(it is ok, just LCD is broken)? Many thanks!!!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
What you'll have to do is replace the LCD and Digitizer (usually glued together) however this part is scarce, so check ebay. The guide for installing it is basically the same as this one.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yep, this isn't for sale at ifixit
por
Adicionar a sua resposta
Oleg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 1,441
