Ir para o conteúdo principal
A multi-function laptop released in 2010 by Toshiba. Can be used for leisure, business, or education.
Cooling Fan Replacement main computer.
Primary system fan replacement
I am trying to get into the case of this Toshiba laptop and removing all the screws visible has not allowed me to get it apart. It seems there is something that I am missing in the middle of the laptop and along the side where the CD/DVD rom drive is located that is preventing me from separating the case parts. I have removed the memory and hard drive and see no other parts to remove to get it apart. I have checked the labels to see if there are any hidden screws and there are none. Please help. Thanks.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Have a look in the Toshiba manuals section. There are several model with a case really close to yours so it is most likely one of them can guide you through the process (I have a Toshiba a500 which looks really similar to your computer).
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sardior será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 429
