Ir para o conteúdo principal
How do I bypass the code of a water damaged iPhone 5?
I Have a customers IPhone 5 that is watered damaged. I have dried and brushed the IPhone with alcohol. The phone works but the screen will not turn on. I can hear seri and the vibrator. I just need to extract the info. How can I do the without the screen working?
Thank You
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
did you check the components around the LCD connector?
por
Adicionar um comentário
1 resposta
If you're hearing Siri, cleaned the motherboard etc. with alcohol, there's just the contaminated LCD + Touchscreen, you need a new one.turn off your iPhone with replacing the batterie and than get start changing the screen
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
chapsh2o será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 117
