Ir para o conteúdo principal
Guias de reparo e suporte para o seu Apple Wireless Keyboard. Conecte e comande o seu computador Apple sem fio.
Why "k" key doesn't function?
Hi, the "k" letter of my keyboard is dead, I tried connecting my keyboard to two different machines (Mac and Win) with the same results. I tried to take the key off and clean it, but nothing changed.
Any ideas??
Thanks
Esta é uma boa pergunta?
Pontuação 5
2 comentários
I have 3 original Apple wired keyboards all with a malfunctioning K key - typing anything with a "k" included needs visual check to ensure it appears... otherwise its repeated tapping to get a response.
por Compartilhar
Had the same problem with letter Y...if it' not a software issue like speech dictation or similar, or mechanical issue like spilled liquid try removing the cap of the letter than adjusting the rubber connector...than take a pointy object and try pushing the key and gently adjusting the rubber connector. It has worked for me
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Here's the only solution I could find to a single malfunctioning key on that particular keyboard: http://www.omninerd.com/articles/Apple_C...
Esta resposta foi útil?
Pontuação 4
3 comentários:
Thanks Mayer, I only press the k key, but nothing happen, upper o lower case is the same.
Thanks a lot
por Compartilhar
Thanks
por Compartilhar
That site appears to have been hijacked.
por Compartilhar
Adicionar a sua resposta
mvmarroquin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 19,072
