Ir para o conteúdo principal
Repair for LED, incandescent, and other handheld electric light sources.
20 Perguntas Visualizar todos
What LED flashlights are best for hunting/fishing?
I am looking for some flashlights for hunting and fishing. When I check the Surefire site, I thought the flashlights are good, when I check Tank007 tactical flashlight, they seems good as well, So, what hunting flashlights do you use? Which one is better?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
#1 WATERPROOF
  1. 2 heavy enough to knock the prey out with the first blow
Esta resposta foi útil?
Pontuação 1
1 comentário:
Shockproof helps there too
por
There are many LED flashlights on the market. You should read this review to pick the best one for you.
Pontuação 1
It depends, note if your flashlight uses 18650 and beware of those cheaply made ones.
you can visit http://flashlight.nitecore.com/
Pontuação 1
Adicionar a sua resposta
katherinegreen550 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 542
