Ir para o conteúdo principal
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
22 Perguntas Visualizar todos
Can not charge the phone anymore
I have tried numerous plugs but always I must wiggle the cord in order for the phone to charge.. Now I cannot charge the phone anymore
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Initially my Mi4 screen was damaged and managed to retrive by a local service centre at Madurai.
But now the battery is not charging from past one month and thus changed the new battery also. No use....Now it is as a table weight to the cost of Rs. 20,000/-. Worst service centres for Mi phone...
por
Exactly same situation with me, phone is of no use from last 3 - 4 months. If found any fix please let me know, as i have tried every thing like changing micro USB charging port of phone, charger and cable etc. but no success achieved yet.
por
Adicionar um comentário
5 respostas
Pergunta mais útil
i have problem in my phone im 3 when plug charge show 0% cant increase this percentag
Esta resposta foi útil?
Pontuação 4
1 comentário:
Somebody have a solution ?? I have some solution , but I still not try ... I for now change charging port and replace new battery , but problem stay ...
por
I fixed my charging problem!
1- I cleaned carefully the mini USB phone entrance with a needle, paper and blowing air.
I found a lot of dust from my pockets and maybe that was blocking the charger....
2- I bought really good charge from Sony and I tried plugging it in different directions.
Good luck and I hope you can fix it...
Pontuação 0
I changed the charger and kept phone on charging for few Hours. it started and working fine. what i figured out this normally happens if your batter drains too low. once it starts down allow the phone to drain again. this worked for me and saved my 6000-7000 Rs which Service Center was claiming to resolve the issue by changing motherboard.
Service Center guy will dis-assemble all the components and assemble them again. you can watch video in your tube for the same. doing this resets the phone and it resolves the problem in majority of cases.
https://www.youtube.com/watch?v=HEcbB7Gg...
Pontuação 0
1 comentário:
Please reply bro my mi 3 had 1%charge and had got 0% at switched of I went and plugged it in for charge I could not find the red light please help me bro
por
you can get a data cable if does not wrok .i think this Charging cable is broken.
Pontuação 0
1 comentário:
My redmi note 4 got wet in rain and now my phone is not charging properly, what should i do, please anyone help me
por
Its one and only one solution..and solution is that your phones jack is damaged change it .thats it dont believe in others opinion
Pontuação 0
Adicionar a sua resposta
tom balon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 31,204
