Ir para o conteúdo principal
The Kia Optima is a mid-size car produced by Kia Motors beginning in 2000 and marketed globally with various names. Firsts-generation cars (2001-2005) were generally sold as the Optima, though the name Kia Magentis was used in Europe and Canada when sales in those regions began in 2002.
2005 Kia Optima will turn over but wont start
We replaced crank shaft position sensor. Everything is in time. Put it all back together and tried to start it all it does is turn over but start. Any suggestions
Esta é uma boa pergunta?
Pontuação 2
4 comentários:
is your check engine light on? have you checked for any trouble codes with an OBD2 reader? why did you replace the crankshaft position sensor and check timing? your post needs more context, and there are other forums that may be more appropriate for your problem... http://www.optimaforums.com/forum/ for example
http://www.linnbenton.edu/auto/perform/n...
http://www.aa1car.com/library/car_wont_s...
por
The car had check engine light on we had it checked and it said it was crank position sensor. We checked the kia forums with no help. thank you
por
Have you checked to be sure the sensor is properly grounded? Clean under the washers and add some silicon grease where the wire hits the ground lug. Look at the wiring diagram. I'm going to guess it's a black wire going to a lug in the near center firewall, but that's only a guess.
After clearing the CEL and replacing the CPS, is the car throwing another code?
por
Not throwing any other codes. Thank you for your input. If this doesn't work guess it will be going to a shop.
por
Adicionar um comentário
1 resposta
Same for my car 2005 kia Optima . Cranks but will not start . Check coils packs “ only has 2 . I has a sensor that goes under cover for with the spark plugs . Has 12 volts coming out of it . Any chance you know what that sensor is for ? Only has single wire going to it . Sensor is burn up “ looks like it got hot .
Esta resposta foi útil?
Pontuação 0
1 comentário:
This is exactly what is happening with mine as well Judy. It was throwing the code for the crankshaft position sensor so I replaced it and now it won't turn over at all and is still throwing the same code.
por
Adicionar a sua resposta
judy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 46
Ao todo: 3,579
