Ir para o conteúdo principal
Modelo do início de 2011: A1278 / processador i5 de 2,3 GHz ou i7 de 2,7 GHz
Battery not charging at all
Ok welll i have problems with my battery charging, i have done a SMC reset, test with differents power adapter and got 2 new battery because i though they where dead. But when the new battery came it works just fine and it read that it had 50% charge and all, but the next they the computer battery was dead and it was with the power adapter and now it wont charge and as i said i have reset the SMC
Esta é uma boa pergunta?
Pontuação 6
1 comentário
Hi was my answer helpful? do you need any more help?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Check R7051 & R7052, as well as R7021 & R7022. I mean with a multimeter, when these blow they often look perfect. Further, see if the magsafe light turns orange when the laptop is off.
Esta resposta foi útil?
Pontuação 3
Something like this are most likely cause by fake aftermarket chargers or liquid damage.
Can you inspect the chip i highlighted to see if it is any burn marks or corrosion?
Imagem
Pontuação 1
Adicionar a sua resposta
siul2893 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 1,266
