Ir para o conteúdo principal
Model A1213 / 8, 16, or 32 GB capacity
216 Perguntas Visualizar todos
Can I test the Mother board only using the USB cable?
I am trying to test a 1st Gen motherboard only. It does not have a battery attached or headphone jack.
Should Itunes see it when it is plugged into the USB port of my computer? Or does it at least need a good battery attached?
I plugged it in and got no indication that it was connected on the computer screen.
This was purchased used and I was trying to prove that it works. The previous owner stated that it was tested with a fire wire cable.
Thanks in advance,
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
no, the cable isn't enough for that - the battery would be the minimum.
and for the firewire thing - you can only charge the ipod touch with it - syncing is not possible with those cables
Esta resposta foi útil?
Pontuação 2
1 comentário:
Markus, Thanks ! That makes me feel better about my purchase. I will have to get a battery on it.
Pontuação 0
1 comentário:
you're welcome, as a additional information - i#ve tested it on a 2nd gen ipod touch - when i plugged in the cable, it try to boot and then restarts - the power from the usb cable isn't enough to use the upod . but it tried to start
por
Adicionar a sua resposta
barlowdo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 1,505
