Ir para o conteúdo principal
Installation on hard drive.
I installed a new IDE(ATA) 2.5inch hard drive in iBook G4. While trying to install MacOSX, it says "can't install onto this HD." How come?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Several questions come to mind.
1. Did you prep the drive--partition and format before trying to load the software.
2. What operating system are you trying to install--if your processor is at least 933 you can use 10.5 if your memory is maxed but I would recommend staying with 10.4.
I am including a link to an Apple guide to installing software. This guide is for reinstalling but has useful info that may help you. Good luck. Ralph
http://support.apple.com/kb/HT3200
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
fukuiteru será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 600
