Ir para o conteúdo principal
Harley-Davidson Sportster Motorcycles from 1986 to Present.
How do I change my starter?
how can i change my starter for a 07' sportster
Esta é uma boa pergunta?
Pontuação 0
1 comentário
How to change a starter on a 1999 sportster
por
Adicionar um comentário
2 respostas
Pergunta mais útil
It won't be fun.
1. remove battery
2. remove primary cover (leftfoot peg probably needs to come off to do this)
3. remove rear exhaust pipe
4. remove (you might get away with just loosening this) the drivebelt front sprocket cover (right footpeg and front muffler might interfere)
5. remove starter wiring
6. remove starter bolts
7. remove starter
reverse procedure to install
In addition to the starter itself, you'll want to have gaskets for the following:
- rear exhaust port
- exhaust crossover tube
- primary cover set
and oil to refill the primary chain case
Esta resposta foi útil?
Pontuação 1
How do you change starter in 86 harley sportster 883
Pontuação 0
2 comentários:
I think that is first year evo, so it should be similar to above.
por
Ok thanks it's alot of work to remove the starter
por
Adicionar a sua resposta
Israel Sandoval será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 51
Ao todo: 8,313
