Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Pergunta encerrada
Battery replacement heating up
I was replacing my battery and when i connected it, it started making noises and then it stopped. While i was screwing back the pieces, i felt it heating up so i disconnected it. What should i do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Get yourself another battery, a high quality or a genuine one. this one will damage your phone.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I found that it's not the battery that is heating up but the area around the Qualcomm modem. It stopped heating while i was assembling and when I turned it on, it works fine but started heating up again. The source was from right below the sim card slot. My phone worked fine aside from the heating but the screen would suddenly show blue vertical lines, and would reboot. Should I change the battery? I bought a genuine battery. Is there anything else i should replace?
por
When you install a battery replacement by yourself, such as when you purchase it from Ebay or Amazon, you run the risk of having a faulty one which can eventually damage your hard drive and phone. Take it out immediately and replace it with a genuine one
Pontuação 0
1 comentário:
I bought it from a trustworthy supplier. Didn't get it from Amazon or Ebay to avoid that.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 122
