Ir para o conteúdo principal
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
What would be the max. HD capacity when replacing internal drive?
I want to upgrade the internal hard drive. It appears to be a 30 gb . How large can I go as far as storage and the ibook still recognize it? Also what type of drive should I be looking for. Example " ATA 2.5 inch"..
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Without jumping through hoops to get it formated, you should stay under 128GB. An ATA or IDE drive will work fine. Just stay away from the SATA drives. This drive will work just fine for you: [produto vinculado ausente ou desativado: IF107-024]
Here's a bunch of new IDE drives up to 320GB that will work for you: http://eshop.macsales.com/Search/Search....|0&N=6885
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
James Brizendine será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 704
