Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone xr. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 6.
Where is the memory card
Location of memory card
Esta é uma boa pergunta?
Pontuação 9
5 comentários
good day guys I Have a concern my Iphone 6 is 64GB but they always said that my phone is not enough memory? so i can download the i want..
por
I have 6gb storage in my iPhone 6.How to increase it
por
I have 128 GB in my iPhone, but it's showing no space, can't help..!!!
por
Where is the iPhone memory card
por
how can i increase storage in iphone6
por
Adicionar um comentário
5 respostas
Solução escolhida
here it is
Esta resposta foi útil?
Pontuação 7
15 comentários:
There is no memory card inside iphones. apple use BGA chop to do all memory functions
por
Thanks. I had a water damaged iPhone 6 that carrier At&t wanted me to return to them and they said for my safety, to remove the SIM card (I did do that) and the memory card (I didn't do that because I couldn't find it). I assume there is no problem then, right?
por
No problem. That's way the Apple handling replacements
por
Hei buddika i am sri lankan and i want to contact u regarding a iphone problem is there a way i can contact you
por
Hello Nipuna, Welcome to ifixit, post your question here i'm happy to help you and here many professional volunteers who can help you to fix your phone yourself
por
Exibir mais 10 comentários
Is it possible to switch memory card to a working logic board if my phone is dead and I need a backup
Pontuação 2
5 comentários:
Flash module soldered to logic board and you will need high level BGA reworking skills to replace it, even if you replaced it you want be able to decrypt the encrypted data on dead. Simply, answer is NO
por
Simply answer is yes actually. The nand CPU and baseband use cryptographic paring, you would have to replace all 3.
por
Q. How can I even search for a place that would be able to replace the parts on a new board? My phone is smashed. Major damage. No power. But I think if I took to a cca house they could do it. I would pay. I just want my pictures and videos
por
were you able to recover your photos and videos? if so how'd you do it? My phone is in the same condition as you described yours to be. I too need to recover my photos /videos. Any suggestion you might have would help . Thank You
por
I would also like to know the answer to last 2 questions above. I have an iPhone 6S water damaged. It started making a sizzle popping sound as soon as I took it out of the puddle. Took it to a local guy and he tried a new screen and battery, no signs of life. I need this fixed to do a much needed back up to my new phone. Any suggestions? Does anyone know if Apple replaces certain components on the motherboard? Thanks in advance
por
The memory card id inside the actual iPhone if you want to get a bigger one i recommend buy a new iPhone and don't struggle
Pontuação 1
2 comentários:
how can i expand my memory card?
por
How do you know if your phone is done for if it fell in water
por
iPhone does not have a memory card that you can change.
However, you can add expanded storage as a separate drive via the lightning dock.
https://www.sandisk.com/home/mobile-devi...
There is also an external SD Card reader available.
https://www.apple.com/shop/product/MJYT2...
Pontuação 1
I just watched a handy person do the replacement on YouTube (a white guy living in China) it took him three weeks
a special logic board holder, torch, microscope, special soldering ball grid and dozens of dead logic boards to practice
the removal and replacement of the memory chip before he was confident enough to remove and upgrade his own with a larger one. He also had to buy a special board flash chip reprogrammer and reader. So while yes it’s possible to do this and in China there are ,any technicians who do this every day, this is an expert level repair and replacement.
There are two YouTube people who do this repair. A man in New York Louis Rossman, the video I watched last night was a YouTube called strange parts, How I upgraded my iPhone memory by 800%… I wish you much luck.
Pontuação 0
Adicionar a sua resposta
Ruth Laug será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 88
Ao todo: 80,637
