Ir para o conteúdo principal
The BRCK v1 is a self powered mobile wifii device. It is used in all countries and provides internet service in remote areas.
Why won't my BRCK v1 turn on?
The device will usually not turn on, but when the device does turn on, it does not hold a charge.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
If your device won't turn on or won't hold a charge, then one of two things may need two happen. You may have a faulty battery in which that part of the device will need to be replaced. Another issue may be that the connection to the battery may be bad or disconnected all together. For both of these issues, refer the BRCK v1 repair guide. Battery Replacement [link de guia inválido]
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Cory Ihnotic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 191
