Ir para o conteúdo principal
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211 Perguntas Visualizar todos
Cannot connect to wifi
my phone's wifi is not working
my wifi signal strength is very strong but it's not able to connect
the status shows obtaining IP address
and after a while it tells network disabled. Poor connection
I checked on the net they say it's because of the update of the phone original version 4.1.1 to 4.1.2 jelly bean, the update is causing the phone wifi connection go crazy
I checked for the solution, in many forums they showed to change the IP settings from DHCP to Static which I did and then after entering the wifi password there is no save option
I tried this way too..the link is below
https://www.youtube.com/watch?v=zyO66lqT...
the first way is dialing *#0011# but it's still not connecting
the second way was too confusing so I didn't try
I checked it online and I guess this problem does not only happen in note 2 but almost all the android phones
Esta é uma boa pergunta?
Pontuação 5
1 comentário
I have the same problem suddenly in a day. I reset my phone once and I downloaded the wifi fixer, diff., versions, it just does not work.
por
Adicionar um comentário
6 respostas
Pergunta mais útil
my phone is not connecting to wifi and bluetooth
Esta resposta foi útil?
Pontuação 1
Hi Smriti
Have you thought about the wifi antenna being faulty and to try a replacement?
Pontuação 0
2nd Rssi is not available
Pontuação 0
disconnect then put your password back in. that what i did.
Pontuação 0
I can not connect wifi in my mobile
Pontuação 0
I would recommend replacing the WiFi antenna.
Pontuação 0
Adicionar a sua resposta
Smriti Sharma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 25,361
