Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Hard Drive Upgrade Limit
What is the Hard Drive Size Upgrade limit for a
Apple Mac Mini 1.66GHz Intel Core Duo Computer, Model MA607LLA
original configuration -
1.66GHz Intel Core Duo processor
2MB L2 Cache
667MHz Frontside Bus
512MB of 667MHz DDR2 SDRAM (PC2-5300) on two DIMMs; supports up to 2GB
60GB 5400-rpm Serial ATA hard disk drive; optional 80GB, 120GB or 160GB drive2
Combo drive (DVD-ROM/CD-RW)
Built-in AirPort Extreme and Bluetooth 2.0
Apple Remote
Esta é uma boa pergunta?
Pontuação -1
1 comentário
I have changed from 80GB to 500GB and it works just fine.
por
Adicionar um comentário
3 respostas
Solução escolhida
Your machine uses a Serial ATA standard 2.5" hard drive. The largest drive I found that would work for you is 640 GB: http://www.ifixit.com/Apple-Parts/640-GB...
Here's an excellent tutorial on how to replace it: http://soledadpenades.com/2007/11/01/diy...
I just discovered this and thought it might be of interest: CPU can be replaced with a faster "Socket M"/"Socket M" Core Duo or Core 2 Duo
Esta resposta foi útil?
Pontuação 4
1 comentário:
Very nice guide. + Ralph
por
Now that 1TB HDs with 9mm height are available, you can also upgrade the internal HD to 1 Terabyte. I just finished it and it works fine :)
Pontuação 2
The Western Digital Scorpio Blue (WD10TPVT) 1TB fits. Its has a12.5 mm height and I have one installed in the upper bay. Its snug but works fine.
Pontuação 1
Adicionar a sua resposta
David Bell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 9,205
