Ir para o conteúdo principal
A depository for information on the topic of Plastics. To include restoration techniques such as De-Yellowing, Repairs, and Modification.
9 Perguntas Visualizar todos
How do you take off paint scratches from a plastic surface?
I just wanted to ask how I would take off some white wall scratches off of my plastic vacuum ?
is there any type of liquid you can find at home that takes away that stuff?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
First you'll want to try one of the Citrus oil cleaners like: Goo Gone. Just test it out some where it won't show first. They do a good job on label adhesives as well. I would then try using a polishing powder like: Bon Ami with a damp cloth as it won't scratch. After either you do want to put on a protectant like: Armor All.
Esta resposta foi útil?
Pontuação 5
1 comentário:
thanks so much for the help I really appreciate it :)
por
There are a variety of plastic cleaners, polishes, and compounds that work well for this. I have found Novus Plastic Polish Kit to work wonders; Meguiars has variety of products based on color and type of plastics; Mothers also has a polish for scratches.
Pontuação 1
First step is to remove the wall paint without Scratching the plastic surface. Dry wall paint gets soft with - water! No rocket science needed. If possible submerge it into water with a dash of dish cleaner for some minutes. Than take a wooden spatula or fingernails to scrub it from the surface. Any scratches you can polish with toothpaste or grease based polish like mentionned before.
Pontuação 0
Adicionar a sua resposta
yataouss será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 72
Duração total: 7,350
