My beats pill dont work
my beats pill 1.0 was working yesterday, i plugged the charger on it , when i removed the charger it doesnt turn on and the charger usb is lighting red even the charge is not plugged on it
Esta pergunta é pertinente?
You can try charging it form a computer. If that helped, your charger is faulty.
Also, here's the way to reset it, in case charging still doesn't work.
Press and hold the b button and the power button for 10 seconds
The LEDs will blink red and white 3 times... You're done.
Esta resposta foi útil?
This works like magic!!!
When I use a different charger, my pill don't charge or go on. It happened before and lasted a week or two and then it started to work. What's the problem?
I think my charging ports all screwed up because I have to hold the charger a certain way and it doesn't even stay charging long. I don't have original charger either
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 18,927
