Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Creaking noise caused by clips
Hello,
The lower case is connected to the upper case with two plastic clips near its center. In my case this caused the mac to make creaking sounds when putting pressure on mac near the track pad. After removing the two clips the mac is fine and silent.
But what is the use of the clips and is it save to remove them.
Gr Remco
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Hi,
There is no problem if you remove it, but, you will not able to get a hardware warranty with this mac because you've open it...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Remco será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 904
