Will LCD from a Mercury work in an Onyx?
Will the LCD assembly from a 400 MHz Titanium Mercury work in a 550 MHz Titanium Onyx?
Esta é uma boa pergunta?
I finally got a used Mercury laptop for cheap. It had a bad logic board. I can confirm that the logic boards and keyboards on the Onyx and Mercury are not interchangeable. The Onyx uses PC 133 RAM so it can be used in a Mercury (PC100) but not vice versa. However, I was able to successfully transplant the Mercury's LCD assembly into the Onyx and now I have video. The optical drives, modems and hard disks are also interchangeable.
Esta resposta foi útil?
Since they have different part numbers I would think they are not acceptable swaps, but wait for Ben to be sure. Mercury 661-2539 Onyx 661-2568 Ralph
If you have the other display compare the connectors and cable lenghts. Ralph
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 651
