Ir para o conteúdo principal
The Olympus Stylus Tough 6020 combines advance imaging components with a rugged build so it can go along wherever your adventures may take you.
3 Perguntas Visualizar todos
My camera will not turn on, what do I do?
I keep trying to turn the camera on but it seems to be getting no power and I have not even gone underwater with it yet, so I know it is not due to water leakage. What do you recommend?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Please check and confirm the battery is fully charged and is seated properly withing the battery compartment.
Esta resposta foi útil?
Pontuação 1
I have the same problem I turn it on unit makes a clicking noise and beeps then shuts itself down. Have a new battery fully charged.
Pontuação 0
1 comentário:
Same deal! Mine is at least ten years old and eventually started doing this a few years ago, even with a full battery. Wondering if it was a part that went bad over time due to extreme heat/cold or leaked while underwater as it has seen all of these conditions. I will dig into this and hopefully find an answer.
por
Adicionar a sua resposta
Taylor Carabin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 645
