Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
What could stop it from booting when optical drive is connected?
Won't boot, I get blue screen only. When optical drive is disconnected, it works. Replaced the optical drive and hard drive without solving the problem. Is it the optical drive data cable or something else?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
the SATA cable could be damaged, they can be a system killer, my pc wouldn't boot a few months ago, and after a new motherboard, and new RAM, it turned out that the SATA cable was the culprit, the logic board, might be bad (worse case scenario)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
lmmartinez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 550
