Ir para o conteúdo principal
The fourth generation of the sport utility vehicle known as a full-size Bronco, the successor to the early Bronco.
How can I tighten my steering?
In my Bronco the steering column has tons of play. How do I tighten it?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
There are two types of free play in steering. Rotational free play and the scary kind where you wonder if the wheel is going to fall into your lap. The former type is adjusted under the hood with a end wrench and screwdriver. The latter requires you remove the steering wheel to tighten the screws that hold a certain amount of load on the bearings in the column. The screws are usually holding the tilt wheel "knuckle" to the upper part of the shaft with the steering wheel. There is a metal plate for the steering lock under the wheel with holes in it allowing you to tighten the screws.
If the screws or bolts are tight, you may have bad bearings and need a replacement column.
I hope this helps.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you, It is rotational play, I saw the adjustment I just wanted to consult someone with more knowledge before so I don't screw anything up.
por
Older rigs required you turn the screw out (counterclockwise) to take up the slack. I would go one full turn at a time and check free play. If it decreases, then it's still done the same way. When the screw gets tight back it off two full turns and lock it down.
por
Adicionar a sua resposta
Wesley Radecki será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 5,982
