Ir para o conteúdo principal
Lançado em abril de 2014. CPU - Quad-core 2,3 GHz Krait 400, GPU - Adreno 330. Tela - IPS LCD, 16 milhões de cores, 1080 x 1920 pixels, 5,2 polegadas. Memória interna - 16 GB, 3 GB de RAM. Sistema operacional Android, v4.4.2 (KitKat). D6502, D6503, D6543
Xperia Z2 Wont turn on
I recently replaced the LCD screen and after putting it back together it doesn't turn on when the battery is connected. When i disconnect the battery cable the screen lights up and the battery icon shows up. When i plug it back in the LED light flashes three times and nothing happens.
Esta é uma boa pergunta?
Pontuação 10
Adicionar um comentário
8 respostas
Is this whilst plugged into a power source? Was the battery disconnected before the repair?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes...and yes
por
Same problem. Didn't leave the battery connected when I did the job, no. Any solutions?
Pontuação 0
1 comentário:
Same Issue for me too, would be interested if anyone has a solution.
por
Also having this problem. Was all working fine until I disconnected the battery to replace it. :/ Now it will look like it is charging with the red LED, but not actually turn on :/
Pontuação 0
anyone found solution for this?
Pontuação 0
replace the battery work 100%
Pontuação 0
2 comentários:
I just replace my battery as still not working..Dont waste your money
por
I have the same problem, i was thinking of a battery reseat
por
I just replace my battery too. Not working. Dont waste your money. Buy new one.
Pontuação 0
http://forum.xda-developers.com/xperia-z...
Pontuação 0
The flex cable connector is not fully seated. It worked out.
Pontuação 0
Adicionar a sua resposta
Dylon Browne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 7,695
