Ir para o conteúdo principal
The Sony Vaio VGN-NW240F is part of the VGN-NW series, which was released in 2009 and comes in various colors. The laptop has a 15.5” (1366x768 resolution) display with an built-in webcam and a compact ten-keyless keyboard.
How much RAM can I add?
What is the maximum ammount of RAM this pc will support?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hi, According to this supplier the computer will see 4 GB of ram however with a 32 bit OS it will only see 3GB. If you have 64 bit it would see all 4 GB. Link provided-- hope this helps.Be sure you read the upgrade tips.
http://www.memory-up.com/Memory/SonyVAIO...
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
James Comer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 2,577
