Ir para o conteúdo principal
The Comfort Zone CZ6C is a light gray portable desk fan. It has a six inch blade, two speeds, and a hinge mechanism on its neck.
4 Perguntas Visualizar todos
Why is are my fan blades not spinning quickly?
I found this fan in my garage and for some reason the blades won't spin fast enough.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It's probably because dust has accumulated on the blades. You will need to cleanse the blades of any debris. The blades should return to its functional range and speed.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Lol dust does NOT slow down a fan.... that’s literally the laziest dumbest answer I’ve ever heard
por
It has to do with the wiring harness getting old and oxidized mainly. You can try to clean oxidation not unlike with a so,daring iron but a bit more. But dust on blades blows off a fan it doesn’t slow it down lololol.... Sorry I couldn’t resist
por
Adicionar a sua resposta
Gage Wilson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 2,239
