How do I fix the sound on my phone?
The media and all the ringers are all not working even though it says it isn't on silent. When I plug in the headphones, then it works and its the only way I can watch videos.
Esta é uma boa pergunta?
it seems to be your main speaker (Ringer) faulty. you may have to replace it
Esta resposta foi útil?
How do I do that ?
you can get an idea how to teardown it
did you ever figure it out???
I replaced my speaker and it still isn't working what can I do now
Backup all data and reset the phone. check whether speaker back to working condition, otherwise you have to check audio out/ amp section carefully
Turn Bluetooth on and off
Worked like a charm thanks bud
Was having same issue.. Came here for answers...saw a thread that said turn Bluetooth on and back off....worked for me...
Thank you I'll try that
Wirked like a charm wow
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 57
Duração total: 199,916
23 comentários
My speaker is not working how do I do it if u got urs to work...please... Thanks a bunch
por floressusanne
I'm having the same problem. Did you ever get it fixed
por Loka
I got the same problem
por Tyliah Carter
I had to install an app called SoundAbout from playstore.
por Walter Montgomery
When I make call people on other end can hear me but I can't hear them, volume is all the way up and when I get call it only vibrates
por superdave446
Exibir mais 18 comentários
