Ir para o conteúdo principal
The Bose 3-2-1 Home Entertainment System is a series of DVD-based home media systems in the Bose 2.1 home theater line. The Bose 3-2-1 Home Entertainment System was sold between 2001 and 2006 and was available in black and graphite colors.
91 Perguntas Visualizar todos
No fiber optic audio sound connection
Everything on the receiver works except the fiber optic audio connection - so I have no sound to the speakers
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
did you find the answer??
Esta resposta foi útil?
Pontuação 0
You will have to enable it through the Yellow Video cable Menu system.
Pontuação 0
Raajit, is it a special driver or what? As far as I know, the fiber optic audio connection is a very sensitive thing. And I am not sure if the Yellow Video cable Menu system might be a solution on this problem. Maybe, it was just a bug. I have the same matter on my computer. Occasionally, the audio disappears and I can do nothing with it. At some time it returns to its normal working process. It's really strange to explain. And where have you purchased your cable? I know one reliable company which specialize in https://v1fiber.com/ fiber construction and other services. Thanks for your attention.
Pontuação 0
Adicionar a sua resposta
Michael Osburn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 829
