Ir para o conteúdo principal
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
197 Perguntas Visualizar todos
Losing signal with mini display port to vga adapter
At my church we are installing 2014 Mac minis in the classrooms and occasionally when we power them up the main display works perfect but the projector which is plugged in through the mini display port to vga adapter the screen will just be blue like it does't have a signal. When I check in system preferences the computer shows both displays plugged in though. Powering off the projector doesn't fix the problem I have to manually unplug and replug in the adapter.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Was this a problem form the get go? Or did it show up later?
If this is a new adapter I would return it to see if the adapter was bad. If it was working and then started up to be a problem then it could be any of the pieces. Try plugging in a VGA display to see if you can isolate down the problem. Does the display react the same way? If not then its the projector, if yes then you'll need to swap out the cable and adapter as then next easiest things to isolate out. Lastly if nothing changes its the mini that needs service (hopefully not).
You might want to check your buildings grounding and the outlets are correctly wired. Don't forget to get a surge suppressor to plug in your gear (each system should have its own). I would also recommend you talk to your electrician on getting a whole building surge suppressor as well. Heres a good vid on what you should have if you have a lot of lightning in your area and it also talks about the whole building surge suppressor: Ask This Old House - Lightning protection
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Seth Potter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 1,400
