only starts by popping the clutch [AKA] push start
Starts with the key sometimes but, wont take a jump. has a new battery a alternator
Esta é uma boa pergunta?
I'd take it to AutoZone for a free computer check first and see if they can diagnose the issue before spending any bucks.
Esta resposta foi útil?
Check the ignition switch and/or relay. If the relay is intermittent, the current will only be passed when it's cool.
disconnect the positive battery cable while car is on if it shuts off the alternator is no good
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 1,190
1 comentário
Sounds like a bad starter/solenoid. Check for corrosion, bad wiring.
por oldturkey03
