Ir para o conteúdo principal
Repair guides and support for a bevy of Apple AC power adapters.
99 Perguntas Visualizar todos
Pergunta encerrada
What went wrong with my iPad Power Brick?
My iPad was charging as usual, when I hear crackling/sizzling noises coming from the area and smell smoke. I quickly unplug the iPad and discover that the adapter is charred on the inside. What went wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If you have a near by Apple store you might want to take it to them. Clearly something internally failed. What is worrisome here is the fuse links inside failed to blow.
Do you remember where you got it? If you still have your paperwork bring that with you as well.
See what they say and let us know.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Will do, I'll post the results here when I get them.
por
Something inside the adapter may be can't work normally.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 271
